Performing a silent installation
Install the InForm Publisher software on the InForm application server after installing the InForm software.
- In the folder where you extracted the InForm Publisher installation files, edit the installation variables in the setup.iss file. For more information, see setup.iss file variables.
- Run the SilentInstallInFormPublisher.bat file. The SilentInstallInFormPublisher.bat file is also located in the folder where you extracted the InForm Publisher installation files.
Note: The silent installation supports installing on only one InForm database per installation.
