About configuring the InForm Publisher application
You must configure the following parameters for the InForm Publisher software to work with an endpoint and the target application for integration.
- Subscriber—Target application settings including name, assembly, and publisher type.
- Study—Settings for the study from which data is published using the InForm Publisher application.
- Queueing Privilege Grantor user—Database user that grants privileges to the study database user.
- Endpoint settings—Authentication settings for the endpoint used in integration. For example, the user name and password used by the application receiving messages from the InForm application.
Include one Subscriber element definition for each instance of the target application to which the InForm Publisher application publishes data.
As new studies come online on the InForm application server, or if a study on the InForm application server sends data to a different instance of the target application from the instance specified during installation, update the InForm Publisher configuration.
Note: Before updating the configuration of the InForm Publisher software, stop the InForm Publisher service. After updating the configuration, restart the InForm Publisher service. For more information, see Starting the InForm Publisher service.
You can configure the InForm Publisher software from the:
- Command line—Use the PublisherAdmin command syntax to configure the InForm Publisher software from the command line. For more information, see Configuring the InForm Publisher application using PublisherAdmin.
- Publisher configuration tool—Use the tool interface to modify the InFormPublisher configuration file. For more information, see Configuring the InForm Publisher application using the Publisher configuration tool.
For details about the elements in the configuration file, see Descriptions of elements in the InForm Publisher configuration file.
