Configuring a study
- Select the Subscribers tab.
- In the tree, select the study to configure.
The available configuration settings for the study appear on the right.
- Provide the following for the study:
Information for configuring a study
Field
Description
Argus Safety and ODM Extract
Study ID
Not supported.
Low Priority Thread?
True or false, indicating the priority mode of the thread that publishes events:
- True—Thread priority is low.
- False (default)—Thread priority is normal.
Run Startup Validation?
True or false, indicating whether to run validation checks during InForm Publisher startup. If you specify True, the logical schemas/data mappings that were configured in the Central Designer application for use when integrating the InForm application with the Oracle Argus Safety application are validated when the InForm Publisher application is started. This validation identifies missing or invalid mappings that can cause unexpected results in the data published by the InForm Publisher application. The default is True.
For ODM Extract Publisher subscribers, if validation on a custom event fails, the custom event is inactivated and the InForm Publisher application can still start.
Language ID
Not supported.
ODM Extract Only
Enable Audit
If the endpoint type of the ODM Extract Publisher subscriber is CTMS, this option enables or disables storing messages sent from the InForm Publisher application in the audit table.
Note: By default, this option is set to False.
Argus Safety Only
AE Range Starting Offset (days)
Number of days before the onset date of an adverse event that the InForm Publisher application should consider when determining which Adverse Event (AE) forms (in addition to the AE form on which the adverse event was reported) are associated with the adverse event. If an instance of a related AE form has a start date within the range specified in the AeRangeStartingOffset and AeRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all AE forms that were started before the AE onset date, enter -1.
- To include no AE forms that were started before the AE onset date, enter 0.
AE Range Ending Offset (days)
Number of days after the onset date of an adverse event that the InForm Publisher should consider when determining which Adverse Event (AE) forms are associated with the adverse event. If an instance of a related AE form has a start date within the range specified in the AeRangeStartingOffset and AeRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all AE forms that were started after the AE onset date, enter -1.
- To include no AE forms that were started after the AE onset date, enter 0.
Lab Range Starting Offset (days)
Number of days before the onset date of an adverse event that the InForm Publisher application should consider when determining which Lab forms are associated with the adverse event. If an instance of a related Lab form has a start date within the range specified in the LabRangeStartingOffset and LabRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all Lab forms that were started before the AE onset date, enter -1.
- To include no Lab forms that were started before the AE onset date, enter 0.
Lab Range Ending Offset (days)
Number of days after the onset date of an adverse event that the InForm Publisher application should consider when determining which Lab forms are associated with the adverse event. If an instance of a related Lab form has a start date within the range specified in the LabRangeStartingOffset and LabRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all Lab forms that were started after the AE onset date, enter -1.
- To include no Lab forms that were started after the AE onset date, enter 0.
ConMed Range Starting Offset (days)
Number of days before the onset date of an adverse event that the InForm Publisher application should consider when determining which Concomitant Medication (ConMed) forms are associated with the adverse event. If an instance of a related ConMed form has a start date within the range specified in the ConMedRangeStartingOffset and ConMedRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all ConMed forms that were started before the AE onset date, enter -1.
- To include no ConMed forms that were started before the AE onset date, enter 0.
ConMed Range Ending Offset (days)
Number of days after the onset date of an adverse event that the InForm Publisher application should consider when determining which Concomitant Medication (ConMed) forms are associated with the adverse event. If an instance of a related ConMed form has a start date within the range specified in the ConMedRangeStartingOffset and ConMedRangeEndingOffset settings, the safety event data from the related form is transmitted to the Oracle Argus Safety application. The default value is 14.
- To include all ConMed forms that were started after the AE onset date, enter -1.
- To include no ConMed forms that were started after the AE onset date, enter 0.
InForm Adapter URI
Not supported.
InForm user for Adapter
Not supported.
InForm user pwd for Adapter
Not supported.
InForm txn user for Adapter
Not supported.
- Click Save.
