ODM Extract and Argus Safety attributes
- Name—Name for an instance of the target application. The name must be unique across all subscribers.
REQUIRED.
- Type—Publisher type for the specified assembly.
REQUIRED.
For example:
- Argus Safety: PhaseForward.InFormPublisher.Publishing.ArgusSafetyPublisher.ArgusSafetyPublisher.
- ODM Extract: Oracle.InFormPublisher.Publishing.OdmExtractPublisher.OdmExtractPublisher.
- EndPoint—Web service, local directory, FTP or CTMS endpoint URI that the InForm Publisher application calls to update data to the subscriber destination.
REQUIRED.
Argus Safety subscribers support only web service URIs. ODM Extract subscribers support web service, local directory, FTP, or CTMS type endpoints.
The endpoint format is dependent on the endpoint type:
- If the endpoint type is FTP, the EndPointAddress hostname should be in the format:
ftp://<hostname><:portnumber>.
- If the endpoint type is SOAP, the EndPointAddress hostname should be in the format:
http://<hostname><:portnumber> or https://<hostname><:portnumber>.
- If the endpoint type is DIRECTORY, the EndPointAddress hostname should be in the format:
<Drive>:\<directory_name>.
- If the endpoint type is CTMS, the EndPointAddress hostname should be in the format:
https://<hostname><:portnumber>/eai_enu/start.swe?SWEExtSource=SecureWebService&;SWEExtCmd=Execute&;WSSOAP=1.
- EndPointAlias—String value which must match the destination specified for custom events to be sent to this endpoint.
Note: When custom events are defined, a destination is specified to control where the result output for the event will be delivered. The EndPointAlias must match the endpoint name defined in Central Designer.
Required for ODM Extract subscriber.
- EndPointType—Endpoint type to be used for publishing. ODM Extract publisher supports three endpoint types, DIRECTORY, FTP, SOAP, and CTMS.
- FTPLocalFolderPath—Local folder path where generated files are stored before they are transmitted to remote server.
ODM Extract Publisher only. Applicable only when the endpoint type is FTP.
- FTPRemoteFolderPath—Folder path on remote server to which publisher writes files.
Note: When the endpoint type is FTP, use a property file (OdmConfig.properties) to specify the type of data to be pushed. For more information, see the Integration Guide.
- Assembly—Name of the publisher containing the target application subscriber proxy code.
REQUIRED.
For example:
- Argus Safety: InFormPublisher.ArgusSafetyPublisher.dll.
- ODM Extract: InFormPublisher.OdmExtractPublisher.dll.
- HeartbeatInterval—Not supported.
- ScheduledPushInterval—Interval at which the InForm Publisher software:
- Retries actions that previously failed due to errors.
- For Argus Safety Publisher:
- Checks if the SafetyEventUpdateInterval has elapsed, and, if so, sends any necessary updates for existing safety events.
- Checks if the SafetyEventAutoSendInterval has elapsed for any existing serious safety events that have not been sent, and, if so, sends those safety events.
- This value is calculated by the InForm Publisher application and is not directly configurable. The value is set to one half of the lesser value specified for the SafetyEventUpdateInterval or SafetyEventAutoSendInterval, rounded down to the nearest whole number, up to a maximum of 60 minutes. The default value is 60 minutes.
- For ODM Extract Publisher:
- Checks if any event triggers have evaluated positive, and if they have, sends event ODM data to subscriber endpoint. The default value is 30 minutes.
- SignatureFilesPath—Not supported.
- IntervalBetweenRetryAction—Not supported.
- IntervalAfterFailedAction—Not supported.
- MaxNumberRetryFailedAction—Not supported.
