Extensions that show control hierarchy and type
To define details for controls, the ODM Export interface provides the following extensions to the ODM elements ItemDef and CodeListItem.
Oracle extensions to ItemDef
Oracle extension to ItemDef  |
Description  |
pf:ParentOID  |
The parent of each ItemDef that is not a top-level ItemDef.  |
pf:ParentType  |
Defines the type of parent control. If value of parent type is:
pf:SelectionOwner  |
For each ItemDef that is the child of a radio group selection, the OID of the CodeList that contains the codelist selection.  |
pf:ItemDefType  |
Indicates the control type. Values: RadioGroup, Checkbox, Text, Calculated, PullDown, Date.  |
Oracle extensions to CodeListItem
Oracle extension to CodeListItem  |
Description  |
pf:SelectionOID  |
An OID that uniquely identifies the selection in a radio group. The value is a concatenation of the CodeList OID and the CodeListItem CodedValue.  |
