MedML restrictions
The InForm application allows MedML to be installed even if you do not specify the namespace for elements, which bypasses schema validation. As a result, some MedML files that would have failed schema validation (for example, due to invalid case) can successfully be processed. The API enforces strict schema validation and as a result some existing MedML content might need to be altered so that it works with the User Management Interface software.
