SOAP errors
SOAP fault sub-codes defined by the API are interpreted in the http://www.phaseforward.com/InForm/2009/01/UserProvisioning namespace.
Basic summary information is included when available to provide context regarding the cause of the fault. For more information, see Examples: SOAP errors. Detailed error information is written to the server event log.
Fault subcode |
Notes |
InvalidTrial |
The specified study does not exist on the server. |
TrialNotStarted |
The specified study is not started on the server. |
ServerNotStarted |
The InForm server has not been started. |
InvalidData |
Reference to invalid entity (for example, bad site or user name in sitegroup), invalid characters in the input, or schema validation failure. |
ConfigurationError |
API configuration error. |
TransactionTimeout |
Request processing has exceeded the maximum transaction processing window, which resulted in a failure and rollback of processing. |
TrialUrlMismatch |
Study name that is specified in the request does not match the name specified in the URL. |
FailedAuthentication |
Invalid credentials or non-active account. |
InternalError |
Internal, unexpected error occurred. |
