Changing the site study version
To update site study version:
- Use the PutProvisioningData operation.
To update the site study version and return identifier sets for the sites affected:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more <STUDYVERSIONSITE> elements that contain the name of the site and the new study version.
- The SITEMNEMONIC and VERSIONDESCRIPTION values are case-sensitive and must match exactly or an error is returned.
Values: STUDYVERSIONSITE element—Change study version for a site
Field
Required?
Comments
VERSIONDESCRIPTION
Yes
Value is obtained from call to GetStudyVersions.
SITEMNEMONIC
Yes
ACCEPTDATE
Yes
For the format of this field, see the InForm Utilities Guide.
REASON
No
