Creating a rights group
To create a rights group:
- Use the PutProvisioningData operation.
To create a rights group and return an identifier set for each group and user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <RIGHTSGROUP> elements for non-existent rights groups.
- If the GROUPNAME you specify does not already exist, the rights group is automatically created.
Values: RIGHTSGROUP—Create rights group
Field
Required?
Comments
GROUPNAME
Yes
GROUPDESCRIPTION
No
RIGHTREF
No
One or more right refnames associated with the rights group.
USERREF
No
One or more user names to add to the rights group.
A user can belong to only one rights group. If you specify a user who already belongs to a different rights group, the user will be removed from that group and added to the rights group specified by this operation.
ITEMGROUPREF
No
One or more item group ref names associated with the rights group.
