Updating a query group
To update a query group:
- Use the PutProvisioningData operation.
To create a query group and return an identifier set for the group and each user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <QUERYGROUP> elements for existing query groups.
- If the GROUPNAME you specify exists, the query group is automatically updated.
- GROUPNAME values are case-sensitive. If the name you specify does not exactly match an existing name, a new query group is created.
Values: QUERYGROUP element—Update query group
Field
Required?
Comments
GROUPNAME
Yes
GROUPDESCRIPTION
No
USERREF (child element)
Yes
One or more user names to add to the query group.
A user can belong to only one query group. If you specify a user who already belongs to a different query group, the user will be removed from that group and added to the query group specified by this operation.
