Creating a reporting group
To create a reporting group:
- Use the PutProvisioningData operation.
To create a reporting group and return an identifier set for the group and each user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <REPORTINGGROUP> elements for non-existent reporting groups.
- If the GROUPNAME you specify does not exist, the reporting group is automatically created.
Values: REPORTINGGROUP element—Create reporting group
Field
Required?
Comments
GROUPNAME
Yes
GROUPDESCRIPTION
No
USERREF (child element)
No
One or more user names to add to the group.
