Associating a user with a signature group
To associate a user with a signature group:
- Use the PutProvisioningData operation.
To associate a user with a signature group and return an identifier set for the group and each user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more <SIGNATUREGROUP> elements containing the signature group name and list of users to be added to the group. If the specified signature group does not exist, it will be created.
- InForm users are associated only with a single signature group, which is updated based on the GROUPNAME that you specify.
- GROUPNAME values are case-sensitive. If the name you specify does not exist, an error is returned.
Values: SIGNATUREGROUP element—Associate a user with a signature group
Field
Required?
Comments
GROUPNAME
Yes
USERREF (child element)
Yes
One or more user names to add to the group.
A user can belong to only one signature group. If you specify a user who already belongs to a different signature group, the user will be removed from that group and added to the signature group specified by this operation.
