Previous Topic
Next Topic
Book Contents
Silent installation
The file setup.iss contains the pathname of the installation location.
  1. Download the InForm User Management Interface software from the Oracle Download Center, and extract the ISO.
  2. Navigate to the location of the installation files on the downloaded ISO image.
  3. Locate the file setup.iss. If necessary for your configuration, use a text editor to change the values of the following variables in the setup.iss file.
  4. Save and close the file.
    Variable
    Description
    SilentInstallLocation
    Specifies the location where the InForm User Management Interface will be installed.
    Default:
    C:\OracleHS\InForm SDK\Provisioning
    SilentInstallLogOn
    Specifies whether a log is written for the silent installation.
    Values: TRUE, FALSE.
    Default: TRUE.
    SilentInstallLogPath
    Specifies the complete path to the location of the silent installation log. If the directory does not exist, the silent installation program creates it.
    Default:
    C:\temp\ProvisioningSilentInstallLogs
  5. To begin the silent installation, double-click the file silent_install.vbs.
    The InForm User Management Interface is installed.
Send Feedback
