Updating a rights group
To update existing rights groups:
- Use the PutProvisioningData operation.
To update existing rights groups and return an identifier set for each rights group and user
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <RIGHTSGROUP> elements for existing right groups.
- If the GROUPNAME you specify exists, the rights group is automatically updated.
- GROUPNAME values are case-sensitive. If the name you specify does not exactly match an existing name, a new rights group is created.
- Values for the fields are identical to those used when creating a rights group. For more information, see Creating a rights group.
