WSDL
The API definition is included in the WSDL.
The WSDL and associated schemas are included in the InForm SDK\Provisioning\wsdl directory of the installation directory.
Because WSDL contain references to the server on which they were generated, you must update the server name in the WSDL before the WSDL can be used in your program.
You can update the code in either of the following ways.
- Update the server name manually.
The following example of WSDL code shows in bold text the areas you must update.
<wsdl:service name="UserProvisioningService">
<wsdl:port name="UserProvisioningService" binding="tns:UserProvisioningService">
<soap12:address location="https://machineName/sdk/provisioning/UserProvisioningService.svc" />
<wsa10:EndpointReference>
<wsa10:Address>https://machineName/sdk/provisioning/UserProvisioningService.svc</wsa10:Address>
</wsa10:EndpointReference>
</wsdl:port>
</wsdl:service>
