If the InForm software is reinstalled on a system with the User Management Interface
If you reinstall the InForm software on a system on which the User Management Interface software is installed, you must update the following registry key after the InForm software installation has been completed:
HKEYHKEY_LOCAL_MACHINE\SOFTWARE\OracleHS\AuthenticationFilter\ByPassKeyPhrase
Value: sdk/provisioning
