Enable WSDL
The WSDL generation is disabled by default. To enable it, you need to make the following changes to the web.config file under the Provisioning directory of your install.
- Uncomment the following line:
<endpoint contract="IMetadataExchange" binding="mexHttpBinding" address="mex" />
- Find the line:
<serviceMetadata httpGetEnabled="false" />
and change it to:
<serviceMetadata httpGetEnabled="true" />
