PutProvisioningDataAndGetIdentifierSets
Use |
Creates or updates a set of provisioning data for one or more users and sites. Returns identifier set information for all sites, groups, and users in the MedML elements. |
Inputs |
Outputs |
Identifier set list, containing an identifier set for each item that has been modified. Items include: users, sites, rights groups, query groups, signature groups, reporting groups. |
Side effects |
Items are created or updated based on input parameters. Note: PutProvisioningDataAndGetIdentifierSets has the same effect on the InForm study database as PutProvisioningData. Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client, because the method is significantly slower than PutProvisioningData. |
SOAP action |
http://www.phaseforward.com/InForm/2009/01/UserProvisioning/PutProvisioningDataAndGetIdentiferSets |
Note: New users that you add with the User Management Interface must have an associated rights group to be able to log in to the InForm application.
