Document window
When you open a document or online help, the document window opens and displays the following panes:
- Document selection—Contains a tab for each document that you can display.
- Table of contents (TOC)—Displays the table of contents for the trial documents and online help. While you are viewing online help, you can also display an index in this pane. Use the contents and index to navigate to specific parts of the document that is displayed.
- Document text—Displays the text of the open document.
- Navigation—Contains buttons that let you navigate through the standard trial documents and online help, and close the document window.
