Finding a patient by patient number
You can find a patient and navigate directly to the Time and Events Schedule of the patient.
To find a patient:
- On the navigation pane, in the Find Patient field, type the patient number.
Note: Type only the patient number in the field. Do not include the initials.
- Click Go.
The Time and Events schedule for the patient appears.
If the InForm application finds more than one patient with the same number, the content pane displays a list of case books for all sites where a matching patient number exists. You can click the underlined Patient or Status links to display the Time and Events schedule for the patient.
