Custom filters
Custom filters let you choose the exact characteristics of the forms that you want to display in the Source Verification listing. You can create a custom filter by editing an existing public filter and saving it with a new name, or by creating a new filter and specifying all filter criteria.
Custom filters appear only to you in the Filter drop-down list.
Public and Custom filters are applied to the list of patient forms that are displayed as the result of your selections in the Site and Patient drop-down lists.
For example, if you select a specific site, then select a patient number 01-003, a list of forms for patient 01-003 appears in the Source Verification listing. If you then select the Not Verified public filter, the list of forms for patient 01-003 is further narrowed to list only those CRFs that meet the Not Verified criteria.
To create a custom filter:
- In the Filter drop-down list, do one of the following:
- To modify an existing filter, select the filter name from the list.
- To create a new filter, select the blank area from the list; that is, make sure that nothing is selected.
- To the right of the Filter drop-down list, click Edit.
The Criteria dialog box appears. By default, all checkboxes are selected.
- To deselect a checkbox, click in the box.
- To deselect or select all checkboxes in a category, select or deselect the All checkbox.
- Select the checkboxes for the criteria that you want the filter to use. You must make at least one selection in each category.
Note: To list all instances of a common form, select CCRF in the Visit category.
- To view a summary of your selections, expand the Criteria dialog box by clicking the arrow icon (
) that is located in the lower-right corner, above the Cancel button. - To save the filter, click Save.
- Provide a name for the filter.
Note: If you started with an existing filter, the name of the filter appears in the dialog box.
- To apply the filter without saving it, click Apply.
After you apply the filter, the following occurs:
- The filter is applied to the list of forms that was displayed at the time you clicked Apply.
- Patient records that match all of your selections appear.
- The Criteria dialog box closes.
- The Filter drop-down list displays one of the following, depending on whether you started with a public filter or a blank filter name:
- If you started with a public filter, the name of the filter appears with the words Public Filter in parentheses, and an asterisk. For example,
Not Complete (Public Filter)*
- If you started with a blank filter name, the word Custom appears.
To save a custom filter that you applied without saving
You must save the filter immediately after you apply it, or your edits will be lost.
- The Filter drop-down list displays the filter that you applied. The name of the filter appears as either of the following:
- The word Custom
- The name of the public filter that you edited, followed by the words Public Filter in parentheses, and an asterisk. For example,
Not Verified (Public Filter)*
- Click Edit.
The Criteria dialog displays the criteria that is used by the filter.
- Click Save.
- Type a name for the filter, then click Save.
Note: If you make any changes to the criteria and apply the filter before you save it, the filter appears with the new criteria.
To delete a custom filter:
- In the Filter drop-down list, select the name of the filter you want to delete.
- Click Edit.
The Criteria dialog appears.
- Click Delete.
- In the confirmation dialog box that appears, click OK to confirm the deletion.
