Form submitted successfully messages
After you provide data on a form, you click the Submit button. If submission is successful, the "Form Submitted Successfully" message appears.
Depending on how your trial is designed, the message could appear in either of the following ways:
- As a pop-up message box
If the message "Form Submitted Successfully" appears in a pop-up box, click OK to acknowledge the message and continue using the InForm application.
- As a message in the title bar of the form
The message "Form Submitted Successfully" appears in yellow, to the right of the title of the form. You do not have to respond to the message in any way. You can continue using the InForm application.
Depending on how your trial is designed, the message either remains for several seconds and then fades from view, or it remains visible until you perform another action on the form.
