Overview: Indicating that a form is ready for source verification
You can mark a form to indicate that it is ready or not ready for source verification. This information is used by monitors to determine which data is ready to be reviewed and source verified.
Forms can be marked as follows:
- Not SV Ready—A form has this status:
- After it has been touched (after you enter data in any item or enter a comment to indicate that the form or a data item will be left blank) and before you mark it SV Ready.
- If you mark the form ready for source verification, but then change the data in an item, the InForm application changes the status of the item to Not SV Ready.
- SV Ready—A form has this status after you mark it ready for source verification and before a monitor performs source verification on the form.
Note: To mark a form ready for source verification, you must have the appropriate rights.
