Source verifying data on an online form
To perform source verification:
- In the source verification view of the form, verify each item for which verification is required. Items that require source document verification have a checkbox and are deselected.
Note: When you are verifying data for an itemset, one checkbox is used to mark an entire itemset row as source verified.
- Handle each item as required, as described in the table:
Action
Do this
To indicate that an item is source verified
- For a data item: Select the checkbox that is located in the left column of the row that contains the item.
- To select all checkboxes at once, click the checkmark that is located at the upper-left corner of the form.
- To deselect a checkbox, click the checkmark.
If only a few items still require verification when you finish with this form, you can select all boxes, then deselect the checkboxes for those items that still require verification.
- For an itemset: Select the checkbox. One checkbox marks the entire itemset row as source verified.
To enter a query
- Against an item: Click the query icon that is located in the far-right column of the row. Items for which there are queries have a yellow query icon.
- Against an itemset: Click the itemset row number, then click the query icon for the item you want.
To review a comment
- On an item: Click the comment icon that is located in the far-right column of the row.
- On an itemset: Click the itemset row number, then click the comment icon for the item you want.
To review a comment on the form as a whole
- Click the form-level comment icon that is located at the top-right corner of the page.
To review the audit trail
- Of an item: Click the audit trail icon that is located in the far-right column of the row.
- Of a itemset: Click the itemset row number, then click the audit trail icon for the item you want.
- Click Submit.
In the Source Verification listing, the SV Status entry changes for each form whose source verification state has changed. If a form becomes SV Complete, a checkmark appears next to the traffic light icon of the form, in the following places:
- Source Verification Listing.
- Case Books Listing.
- Time and Events Schedule.
This checkmark is visible if you are in a rights group with the right to monitor CRFs.
