Overview: Data listings
Listings enable you to take a snapshot of patient data and download it. Downloaded listings are in a file of comma-separated values (a CSV file) that you can open in a Microsoft Excel spreadsheet or in another program that reads CSV files.
You choose the sites and the data items you want to capture, and the InForm application generates a listing of each data item for each patient in the database. After generating a listing, and opening it in a Microsoft Excel spreadsheet, you can navigate back from the spreadsheet to the CRF that is the source of the data.
If you need to generate the same selection of data items multiple times, you can save the selection and recall it at a later date to run again.
Note: To generate data listings, you need the Data Export Listings right in InForm Administration.
