Saving a listing specification
If you expect to generate the same data listing multiple times, you can save the listing specification and run it later using the name you give it.
To save a listing specification:
- Create a new listing, but do not generate the new listing.
- Click Save or Save As.
A dialog box appears so that you can specify a name for the listing specification.
- Type a name for the listing specification in the text box.
- Click OK.
After you save the listing specification, you can do either of the following:
- Click Generate to generate the listing.
- Open it at any later time to generate the same information without having to re-specify it.
Note: You can create a listing specification, open it, refine it, and save it under another name by using the Save As button.
