Deleting a listing
If you start a listing and then move away from the Listings page or close the browser window before it completes, or if the listing does not complete before the session times out, the InForm application continues to process the listing on the server. The next time you click the Listings button, the listing that was in process is available for resolution. If the listing has completed, you can download or delete it.
Deleting a completed listing
When you log back on to the InForm application after leaving a listing in process, or when a listing completes during your InForm application session, a window appears prompting you to download or delete the listing.
To delete a completed listing:
- At the bottom of the page, click Delete. You must delete a completed listing before you can generate a new one.
Deleting a saved listing specification
To delete a saved listing specification:
- In the Navigation pane, click Listings.
- Open the listing specification you want to delete. For more information, see Opening a saved listing specification.
- Click Delete.
A prompt box opens, containing the name of the listing specification.
- Click OK.
Note: If you know the name of the listing specification you want to delete, skip step 2, and type the name of the listing specification in the prompt box.
