Logging in to the InForm application
- Open an Internet browser.
- Type the URL for your assigned trial, and press Enter.
The Login page appears.
- In the User Name, type your user name.
- In the Password field, type your password.
- Click Log In.
- If this is the first time you are logging in to the InForm application, the Change Expired Password page appears. For more information, see Logging in to the InForm application for the first time.
- If your login credentials are accepted:
The InForm application opens and displays the Home page for the trial. The Home page is customized for each trial and can include many types of information.
The InForm application displays all the features to which you have access, based on your rights and rights groups.
Your trial allows a specific number of login attempts. If you exceed this number, the system locks you out. If this happens, do the following:
- Reset you password using your password recovery information. For more information, see Resetting your forgotten password.
- Contact your administrator to reactivate your account.
