SV Report
The SV Report (Source Verification Report) is a formatted listing of one or all forms that exist for a patient. When you print the SV Report, you can obtain a complete printed copy of the forms so that you can perform source verification offline. The SV Report consists of two screens: a list of patients for whom you can generate reports, and a page on which you can select the form or forms you want to print. After generating a view of the form or forms online, you can print it by clicking the Print button.
To display the page:
- On the Navigation pane, click Monitor.
- Click the SV Report tab.
Things to note
- Sortable columns—You can sort the report by using the data in the Site, Patient Number, or Patient Initials columns. To change the sort order of one of those columns, click the column heading. In the column used for the primary sort, the heading includes an arrow that indicates the sorting direction.
- Page indexer control—This control enables you to move to a different page of the SV Report list when the information fills more than one page. To use the page indexer control, click the appropriate arrow, or select a page number from the drop-down list.
- Print Preview link—Each Case Book in the SV Printout list has a Print Preview button that enables you to display a page on which you can select the form you want to print or specify that you want to print all forms.
