You find a data-entry error after submitting
A data-entry error might automatically generate a query, if it is caught by the built-in edit checks on a data-entry item. For information about how to correct a data-entry error and answer a query simultaneously, see Answering queries.
To correct an error that does not automatically generate a query:
- Click the entered value.
The Data Value(s) page appears.
- Enter the correct value and select or enter a reason for change.
- Click Submit.
You receive a Form Submitted Successfully message, either in the heading or as a message box. If a message box appears, click OK.
- Click Return.
You return to the form.
