Form help
Form help provides information about how to obtain and fill in patient data in forms. If your trial is set up to accommodate direct linking from a form item to help about the item, you can display CRF help by using that method. You can also open form help from any location in the InForm application by clicking Documents in the Navigation pane. This part of the tour describes the second method of viewing form help.
To display Form help:
- In the Navigation pane, click Documents.
- Click the CRF Help tab, if it is not already selected.
Things to note
- Contents—Form help contents appear in the Table of Contents pane of the document window. To display a specific help topic, click its link in the Table of Contents pane. In this example, help is organized by form.
- Page indexer—The page indexer is a multi-part control on the bottom left side of the Content-specific pane. By clicking different parts of the control, you can move through the pages of form help.
