The new data item value results in a query
If the value to which you change a data item fails an edit check on that item, the InForm application generates an automatic query, which you can answer right away by using one of the following methods:
- Changing the data value again.
To use this method:
- Check that the value was entered correctly.
- Check that the value matches your source data.
- Check the trial documents, including form help, if it is available, to find the range of permitted values for the item.
If you find that the data is in error, change the data.
- Click the current item value, and proceed as described in Updating form data.
- Entering answer text.
To use this method, follow the instructions in Answering queries.
