Submitting results in a screening failure
The Screening Log lists the names of all candidates who have been screened. The Enroll column indicates the following:
Enroll column contains |
Meaning |
Enroll button |
Candidate has been successfully screened |
X |
Screening failed. Candidate is not eligible for the trial. |
If you believe that the candidate should be eligible for the trial, do the following:
- In the Screening Log, look in the Screening Failure column to determine why the screening failed.
- Click the underlined screening number for the candidate to display the screening form. Make necessary changes according to the table:
If screening failed because
Do this
Some screening data is missing.
Complete the Screening form, then click Submit.
The patient is ineligible for the trial.
Check the data and make corrections if necessary. To correct a data value:
- Click the entered value.
- On the Data Value(s) page, type the correct value and select or type a reason for change.
- Click Submit.
- A confirmation dialog box appears. Click OK.
- Click Return to go back to the Screening form.
- Click Submit.
