Finding patches
You can search for patches by patch ID or number, product, or family.
- Sign in to My Oracle Support at https://support.oracle.com.
- Click the Patches & Updates tab.
- Enter your search criteria and click Search.
- Click the patch ID number.
The system displays details about the patch. You can view the Read Me file before downloading the patch.
- Click Download, and then follow the instructions on the screen to download, save, and install the patch files.
