Documentation
The product documentation is available from the following locations:
- My Oracle Support (https://support.oracle.com)—Release Notes and Known Issues.
- Oracle Technology Network (http://www.oracle.com/technetwork/documentation/hsgbu-154445.html)—The most current documentation set, excluding the Release Notes and Known Issues.
If the software is available for download, the complete documentation set is available from the Oracle Software Delivery Cloud (https://edelivery.oracle.com).
All documents may not be updated for every InForm release. Therefore, the version numbers for the documents in a release may differ.
InForm documentation
Document |
Description |
Release Notes |
The Release Notes document describes enhancements introduced and problems fixed in the current release, upgrade instructions, and other late-breaking information. |
Known Issues |
The Known Issues document provides detailed information about the known issues in this release, along with workarounds, if available. |
Secure Configuration Guide |
The Secure Configuration Guide provides an overview of the security features provided with the Oracle Life Sciences InForm application, including details about the general principles of application security, and how to install, configure, and use the InForm application securely. |
Installation Guide |
The Installation Guide describes how to install the software and configure the environment for the InForm application and Cognos software. |
Setting Up a Trial with InForm Architect and MedML Guide |
The Setting Up a Trial with InForm Architect and MedML Guide describes how to design and implement trials in the InForm application using the InForm Architect application. |
InForm Architect online Help |
The InForm Architect online Help describes how to design and implement trials in the InForm application using the InForm Architect application. This information is available from the InForm Architect user interface. |
Step by Step for CRCs and CRAs Guide |
The Step by Step for CRCs and CRAs Guide describes how to use the InForm application to:
Online Help |
The online Help describes how to use and administer the InForm application. This information is available from the InForm user interface. |
Reporting and Analysis Guide |
The Reporting and Analysis Guide provides an overview of the Reporting and Analysis module. It includes a brief overview of the Reporting and Analysis interface, illustrates how to access the Ad Hoc Reporting feature, and describes the trial management and clinical data packages available for Reporting and Analysis. It also provides detailed descriptions of each standard report that is included with your installation. |
Reporting Database Schema Guide |
The Reporting Database Schema Guide describes the Reporting and Analysis database schema. |
Portal Administration Guide |
The Portal Administration Guide provides step-by-step instructions for configuring and managing the InForm Portal application. |
InForm Utilities Guide |
The InForm Utilities Guide provides information about and step-by-step instructions for using the following utilities:
MedML Installer utility online Help |
The MedML Installer utility online Help provides information about, and step-by-step instructions for using, the MedML Installer utility, which is used to load XML that defines trial components into the InForm database. This guide also provides reference information for the MedML elements and scripting objects that are used to import and export data to and from the InForm application, as well as sample data import XML. This information is available from the utility user interface. |
InForm Data Import online Help |
The InForm Data Import online Help provides information about, and step-by-step instructions for using the InForm Data Import, which is used to import data into the InForm application. This information is available from the utility user interface. |
InForm Data Export online Help |
The InForm Data Export online Help provides information about, and step-by-step instructions for using the InForm Data Export, which is used to export data from the InForm application to the following output formats:
Third Party Licenses and Notices |
The Third Party Licenses and Notices document includes third party technology that may be included in or distributed with this product. |
