Customizing predefined lists
The only predefined lists that you can edit are in the following locations of your InForm application installation directory:
- XMLBase\sysform_ClearCRF.xml
- XMLBase\sysform_EditItem.xml
- XMLBase\sysform_ItemEditReasons.xml
- Resources\pfscript.js
Do not change any other files in these directories.
Note: Take care when making changes to predefined lists, and be sure to make changes only to the files discussed in this chapter. Changing other files can result in serious problems in the trial data.
