Rules
Rule definitions specify every aspect of rules that are triggered by events in the InForm application. You can update the following parameters through the administration tool:
- Rule description—Descriptive rule name.
- Status—Status of the rule: Active or Inactive. Only rules in Active status fire when the form is submitted.
- Help Text—User-friendly description of the edit check, calculation, conversion, or randomization performed by the rule. This text appears along with CRF Help for the data items with which the rule is associated.
- Rule Script Text—Text of the script that runs when the rule executes.
