Removing rights from a user
To remove rights from a user:
- In the Trial Objects window, click the Admin icon.
- Click the Rights tab.
- In the List Users column, click the Change Users link for the rights group from which you want to remove the user.
- On the Change Members in Rights Group page, select the user’s name in the rights group members list on the left, and then click the Remove button. To select more than one user at a time, hold down the Ctrl key while selecting each name.
- Click Submit.
