Conflict visit
The Conflict visit is required if you use the InForm Unplugged software to synchronize data across multiple trial instances. This visit is activated if a study version conflict occurs when users on different instances of a trial start the same patient on different versions of the same CRF, and then synchronize. You must create the Conflict visit in the Dynamic visit node. Use the following UUID:
PF_UUID_CONFLICT_FORMSET
