Patient Number item
The Patient Number Item definition is an optional item on the Enrollment form. If you allow users to edit the Patient Number, use the following required UUIDs to define the Patient Number item:
Component |
UUID |
Patient Number item |
3D25EE4C-7F1B-11D2-A728-00A0C977C64B |
Patient number textbox control |
433DAFF6-7F1C-11D2-A728-00A0C977C64B |
