Regulatory Documents (Reg Docs) form
The Regulatory Documents (Reg Docs) form is optional in a trial. If you include a Reg Docs form, it must:
- Occur only once in the trial.
- Use required UUIDs for visit, form, and section.
- Include at least one item.
The InForm Architect application automatically provides the UUID properties in the visit and form. UUIDs for Reg Docs visit, form, and section appear in the following table:
Component |
UUID |
Reg Docs visit |
PF_UUID_REGDOCS_FORMSET |
Reg Docs form |
PF_UUID_REGDOCS_FORM |
Reg docs section |
PF_UUID_REGDOCS_SECTION |
