GROUP and INDEX assignments
The pie chart and bar chart graph the same data from different perspectives. For example, if you reverse the assignment of GROUP and INDEX values—assign site data to INDEX properties and adverse effects to GROUP properties—the bar chart would display sites along the X axis, and the occurrences of adverse effects at a site would be represented via each group of bars.
