Reporting COM object properties by function
The following table describes all the Reporting COM object properties by function. This will provide a sense of “where and why” each property could be used. Detailed descriptions of the properties can be found in the “The Reporting COM object” section.
When you want to... |
Use... |
Notes |
Define a query for the report |
Define chart type |
SetGraphDisplay |
Not required for text formats. |
Define graph parameters |
PieColumnsSetTitle |
The PieColumns property applies only to pie charts. |
Define graph legends and titles |
Extract data from a query |
Extract site and user information |
Associate data with the GROUP/INDEX pair |
SetGraphValue |
Used for either pie or bar charts; not required for text formats. |
Display a report |
GetGraphBits and ImageHTML properties apply to graphical formats; HTML and XML properties apply to text formats. |
Define user/connection activities |
Define a date format |
