Previous Topic
Next Topic
Book Contents
Oracle reserved words
The below table lists Oracle Reserved Words. These words may not be used as refnames or they will cause errors.
  • ACCESS
  • ADD
  • ALL
  • ALTER
  • AND
  • ANY
  • AS
  • ASC
  • AUDIT
  • BETWEEN
  • BY
  • CHAR
  • CHECK
  • CLUSTER
  • COLUMN
  • COMMENT
  • COMPRESS
  • CONNECT
  • CREATE
  • CURRENT
  • DATE
  • DECIMAL
  • DEFAULT
  • DELETE
  • DESC
  • DISTINCT
  • DROP
  • ELSE
  • EXCLUSIVE
  • EXISTS
  • FILE
  • FLOAT
  • FOR
  • FROM
  • GRANT
  • GROUP
  • HAVING
  • IDENTIFIED
  • IMMEDIATE
  • IN
  • INCREMENT
  • INDEX
  • INITIAL
  • INSERT
  • INTEGER
  • INTERSECT
  • INTO
  • IS
  • LEVEL
  • LIKE
  • LOCK
  • LONG
  • MAXEXTENTS
  • MINUS
  • MLSLABEL
  • MODE
  • MODIFY
  • NOAUDIT
  • NOCOMPRESS
  • NOT
  • NOWAIT
  • NULL
  • NUMBER
  • OF
  • OFFLINE
  • ON
  • ONLINE
  • OPTION
  • OR
  • ORDER
  • PCTFREE
  • PRIOR
  • PRIVILEGES
  • PUBLIC
  • RAW
  • RENAME
  • RESOURCE
  • REVOKE
  • ROW
  • ROWID
  • ROWNUM
  • ROWS
  • SELECT
  • SESSION
  • SET
  • SHARE
  • SIZE
  • SMALLINT
  • START
  • SUCCESSFUL
  • SYNONYM
  • SYSDATE
  • TABLE
  • THEN
  • TO
  • TRIGGER
  • UID
  • UNION
  • UNIQUE
  • UPDATE
  • USER
  • VALIDATE
  • VALUES
  • VARCHAR
  • VARCHAR2
  • VIEW
  • WHENEVER
  • WHERE
  • WITH
Send Feedback
