Design notes
As you create and update forms and form components, you can include free-form notes about the components. These notes are associated with each component as properties. They are for documentation purposes only and are not displayed with the components in the InForm application. You can create design notes at the visit, form, section, itemset, item, and control level. Design notes can have a maximum of 255 characters. The following figure illustrates the Properties window for a radio group control, showing the presence of the Design Note property:
