Using the pop-up menu in the Protocol Editor
- In the Protocol Editor window, select the visit to which you want to add a form. If the visit already includes one or more forms, open the visit by clicking its plus icon, and select the form after which you want the new form to be added.
- Click the visit or form icon, or its description, with the right mouse button, and select Add Form from the pop-up menu.
The Add Forms to Visit dialog box appears, showing a list of defined forms that have not already been associated with the visit. Special forms such as Screening and Enrollment are not included in the list.
- From the Add Forms to Visit dialog box, select the form you want to add.
- Click Add.
