Creating a new section
You can create a new section only in the context of the form in which you want to include it. To define the properties of the default section provided when you create a new form, follow the steps described in Defining section properties. If you are creating additional sections, first do the following:
- Open the form in which you want to include the section: double-click its icon in the Protocol Editor window or Trial Objects window.
- Drag the section icon
in the Object Palette toolbar into the open Form definition window. To order the section first in the form, drop the icon onto the Form node. To create a subsequent section, drop the icon onto the section that you want the new section to follow.
