Including an existing item definition in a section
To include a previously defined item in a section:
- Open the form in which you want to include the item.
- Open the Items node in the Trial Objects window.
- Drag the item you want to include onto the section icon in the Form definition window. To order the item first in the section, drop the icon onto the section icon. To create a subsequent item, drop the icon onto the item that you want the new item to follow.
