Creating a new itemset
To create an itemset:
- Open the form in which you want to include the itemset: double-click its icon in the Protocol Editor window or Trial Objects window.
- Select the section in which you want to create the itemset.
- Drag the itemset icon
in the Object Palette toolbar into the open Form definition window. Drop the icon onto the section icon.
