Viewing the items in an itemset
The Form window preview pane for a form that includes an itemset definition shows the itemset as it appears in the InForm application. Each item in the itemset is represented only by its column heading label. The InForm Architect application enables you to see each item with its controls when you select an itemset in the tree view presented in the top pane of the form window. To view a preview that shows individual itemset items:
- Open the form in which you want to view itemset details.
- In the top pane of the Form window, select the itemset. The preview pane changes to the Add Entry view of the itemset, as it would appear in the InForm application when you click the Add Entry button, showing the format of each item in the itemset.
